Help identifying pickups
chrischris
They look like they could be Schaller "Golden 50 Super" pickups.
Interesting 3 screw mounting... might increase the chance they're by Schaller.
Hi guys,
Thanks for the info.
I removed them last night and had a look at the underside, absolutely no labeling whatsoever.
I also looked at the label inside the guitar and it reads "H-575 A513"...does that help at all?
I'm inclined to agree with the general consensus though, 2 screw "tilt" adjustment suggests Schaller to me, and whilst I know they used EMG's for a time there there is no sign of any branding on them.
Does anyone have any ideas as to the value of this baby? It is in great condition, a few tiny chips to the corners on the rear of the headstock, and a few light scratch marks to the rear of the body. Whole top and headstock of the guitar is covered with Lacquer checking too (but I find that kind of charming). It's a "G" serial by the way so that makes it 25 years old, made in Jan too so nearly to the day.
Thanks for the help, loving this forum, very informative! :)
Cheers,
Chris.
I have no clue as to value, but it's a nice guitar for sure!
About the pups, do the brackets allow 4 screws? Or just 3? Schaller brackets normally have 3 holes in each bracket with the middle one being smaller than the other two...
Also the ones I've seen had a 4 connector lead wrapped in crappy grey plastic (that's likely to have changed over the years though...).
Is it possible that " A513 " is actually just a poorly written " ASB " ... = Antique Sun Burst .. the finish..
Hi chaps,
Think you are correct on this one, looked at the photo I took of it and the 5 in "575" is different to the S in "ASB".
The brackets on the Pickups have two holes on one side and just the one on the other, the surround has 3 holes both sides.
Having just 2 holes one side of the pickup says Schaller to me. The photo in the link to the "Golden 50 Super's" that Vanschoyck posted shows 3 holes, but maybe they've changed over the years...?
I think that's what I will think anyway, unless anyone else can offer an opinion.
Thanks again all :)
