Audio Interface for PC
koula901
  On 4/23/2015 at 3:44 PM, mtpatty said:
Kuz- Katie, all- I should have said my Axe-Fx into Apogee Duet into iMac (Garageband)...very little space is needed-
:icon_thumleft: duly noted. Sounds like a great set up.
  On 4/23/2015 at 11:47 AM, Kuz said:
I am a "computer-free" recording defector and won't be swayed from this mission!!!!! :)
I use either real amps or the Fractile Axe-Fx modeler straight into a Tascam BR-1600 (16 track recorder). When I use the amps, I put the amp into a closet and mic it there for a pseudo Isolation chamber (I can turn them up with minimal disturbance) and the mic cord goes directly to the Tascam recorder. I usually use my Focal headphones for tracking (although if I am using the Axe-Fx for modeled amps I can play through the monitors and still record) and use my Focal Monitors to mix with because they are dead-flat and I can pickup "real" Eq issues better than mixing with the headphones. After rough cuts I mix them on the Tascam and use the reverb, delay, Chorus (rarely), and the compression that is on the Tascam. I can then burn a CD, save the project on the Tascam hard drive, or save to a thumb drive.
I am sure that the Tascam recorder is not the most perfect pristine recording source, but it is relatively cheap & easy to use. I have recorded a CD of me playing over backing tracks and the sound quality was as good as I ever need it to be (and most said it was great).
I would rather spend the thousands of dollars that it cost for computer software & interfaces on really decent mics. The cost on these recorders has PLUMMETED due to the software recording frenzy. I paid $1200 for my Tascam BR-1600 about 8 years ago and now they have been updated, 32 tracks, hard drive-free version for $500!!!!!!!!!
Break from the Matrix and spend your time playing & recording.... not learning complicated software & tethered to a screen!!!
This has been a public service message from "The American Computer-Free Recording Defectors of America"!!!!
Some older Pictures of my humble recording studio (down stairs in the man cave).....
I still use a Korg D1200mk2 quite often. Its an older unit now but it seems to work alright.
I didnt ever want to use my computer to record but I have started to use it more and more.
Not familiar with stand alone units, but recording software does a lot more than recording. cubase (and most other daw) offers a number of virtual instruments that can be easily used. Get a csmall midi controller for 200 bucks and on top of the recording device you have also a keybard and a drum machine, not to mention the plethora of effects.
Kuz, if you are using real amps, you might want to check the Mesa boogie cabclone, instead of the closet.
I will check it out, but I like my lo-fi closet isolation chamber!!! :)
