Spectrum13 Posted May 27, 2015 Posted May 27, 2015 Planning to mount a scratch guard on my 150 and wanted to know if a standard LP in cream would fit flush against the Seth Lovers. Anyone retro fit and have suggestions?
HANGAR18 Posted May 27, 2015 Posted May 27, 2015 Any Gibson Les Paul pick guard will work but the holes won't be in the same place. If there are no holes drilled into the guitar already, you can drill your own where they need to go. Or, you might see if Gibson is selling the 2015 Les Paul pickup rings and pick guards separately. The 2015 design allows you to click the pickguard into place and detach it at will with no holes and no tools.
goSteelers Posted May 28, 2015 Posted May 28, 2015 I've had some good luck getting wooden pickguards on ebay. I like them better than the plastic ones. I've never had a problem with them fitting the pickups. If you don't already have holes in the guitar, a Les Paul one will mount just fine. If you do, you may want to order a Les Paul one without holes, and then drill them yourself. I've done that with this guy: http://www.ebay.com/usr/9346billc?_trksid=p2047675.l2559 but I imagine that other vendors that actually make them themselves would do the same. Also, there are a couple vendors that make H150 pickguards: http://stores.ebay.com/CustomReserve (He doesn't have any listed now, but he has had H150 pickguards listed in the past, so he knows how to make them) and pickguards.us makes plastic ones for H150s. Look under miscellaneous, #808 . He has some nice looking patterns.
