pick-up eagle classic 1992 height adjustment
chicobonsai
Hi,
anyone Knows what kind of pickup installed Heritage in the eagle classic in 1992?
Also i try to adjust the height of pole,anyone have any recomendations about?
Thanks
A picture would help, but your Eagle Classic probably has Schaller pickups. If each pickup is attached to the pickup surround using 4 screws, that would confirm. UNLESS the switch tip has a dot on it, then they would be HRW's.
If you're trying to adjust the height of individual polepieces, a slotted head screwdriver should work. Choose a size as close as possible to the slot length and width to ensure max leverage.
Good luck!
Agreed. Likely a Schaller. Adjust the pole pieces until you're happy with the relative volume from string to string.
  • 2 months later...
