samwheat Posted August 5, 2015 Posted August 5, 2015 Who would you recommend to bind headstocks and set the pearl inlay? I have 2 and possible one more to get done. This should be standard with H150's (they look so much nicer). Hint to the factory.
HANGAR18 Posted August 5, 2015 Posted August 5, 2015 Who would you recommend to bind headstocks and set the pearl inlay? I have 2 and possible one more to get done. This should be standard with H150's (they look so much nicer). Hint to the factory. The comparable Gibson offerings don't come with bound headstocks. As in H150 vs Les Paul Standard.
TalismanRich Posted August 5, 2015 Posted August 5, 2015 I agree that the binding makes the headstock look worlds better, and it is an option that can be ordered when you put your guitar together. That's one reason I went with the 157 when I ordered my first guitar. I like the binding, but at the time, I had no clue that you could customize to that degree. If I was ordering today, it would still be a 157, but probably a LW with Seths.
Blunote Posted August 5, 2015 Posted August 5, 2015 Yes, a bound headstock looks better, but they're also more resistant to dents than a headstock without the binding. I'm curious to see if it's feasible to add the binding after the guitar is built. It looks to me like the routing for the binding is done before the fingerboard is attached. I'm not an expert on the topic but I would think whoever does the job would first have to remove the fb, route around the headstock, carefully chisel out the bits just above the nut, apply the binding, sand it flush with the edge & refinish. Yoslate apprenticed with a luthier. Maybe he has some insight. PM him.
Kuz Posted August 6, 2015 Posted August 6, 2015 It can definitely done (even at Heritage, I believe), I asked a former Heritage rep if it could be done at Heritage, and he said, '"Yes it can be done, but you might not like the time frame or the price".
barrymclark Posted August 8, 2015 Posted August 8, 2015 It can most certainly be done. I wouldn't due to likely cost. Sent from my iPhone using Tapatalk
brentrocks Posted August 9, 2015 Posted August 9, 2015 Vince tried to propose this same idea....for bound/inlayed headstocks to be standard.....i'll give you 3 guess who intantly shot it down
samwheat Posted August 13, 2015 Author Posted August 13, 2015 Would anyone recommend RS Guitarworks to bind the headstocks on my guitars? How about Pete Moreno?
DetroitBlues Posted August 14, 2015 Posted August 14, 2015 Pete may not ever touch another Heritage, RS may be able to handle it.
tbonesullivan Posted August 14, 2015 Posted August 14, 2015 The hard part is the finish work. not to mention that the channel for the binding is usually added before the fretboard/nut. Those things can get in the way. Standard? Why? Binding doesn't serve any purpose on the headstock anyway. Heck it barely serves any purpose on a solid body guitar. I also don't see how it makes a headstock more resistant to denting. It's going to dent/chip the binding and knock the finish off. If you don't want headstock dents, be more careful. also lets not for get, every joint on the guitar is another place where you can get finish checking:
TalismanRich Posted August 14, 2015 Posted August 14, 2015 The hard part is the finish work. not to mention that the channel for the binding is usually added before the fretboard/nut. Those things can get in the way. Standard? Why? Binding doesn't serve any purpose on the headstock anyway. Heck it barely serves any purpose on a solid body guitar. I also don't see how it makes a headstock more resistant to denting. It's going to dent/chip the binding and knock the finish off. If you don't want headstock dents, be more careful. also lets not for get, every joint on the guitar is another place where you can get finish checking: Maybe its not structural, but is damn sure makes the headstock more appealing visually (to me). The lack of binding is only an issue if you are buying used. For new orders, just include the binding to start with. Problem solved!
Gtwibs Posted August 18, 2015 Posted August 18, 2015 I feel like the demand for bound headstocks has been crazy on the forum lately. Personally, i think the models that come with it standard (157, 555....) look great and it looks a little out of place on an otherwise regular 535 or 150.
Kuz Posted August 18, 2015 Posted August 18, 2015 For me, I think every Heritage should have a bound headstock and MOP inlay for the Heritage name.
Vanschoyck Posted August 18, 2015 Posted August 18, 2015 For me, I think every Heritage should have a bound headstock and MOP inlay for the Heritage name. Totally with you on the inlay. I don't get why they use that other logo application.
AP515 Posted August 18, 2015 Posted August 18, 2015 I prefer them non-bound myself Me too. It seemed to me that the binding was just to cover up poor edge finishing. If you make the guitar right in the first place, you don't have to go around covering up the edges with plastic.
Millennium Maestro Posted August 18, 2015 Posted August 18, 2015 I say order them however you want them...
FredZepp Posted August 18, 2015 Posted August 18, 2015 Sometimes it's nice to have some binding and nice inlay done...
tbonesullivan Posted August 19, 2015 Posted August 19, 2015 Me too. It seemed to me that the binding was just to cover up poor edge finishing. If you make the guitar right in the first place, you don't have to go around covering up the edges with plastic. Technically the binding serves no structural purpose on a solid body guitar at all. On a Hollow body, it is to increase the glue joint surface area for a more solid joint around the body edges. They put it on the fretboard too for looks, and looks ONLY. The fretboard doesn't need any help staying attached. When they started making solid body electrics, they put binding on it because they wanted to make it look "familiar". like the hollow bodies. People equated it with "quality", when it really means nothing like that.
Blunote Posted August 19, 2015 Posted August 19, 2015 Technically the binding serves no structural purpose on a solid body guitar at all. On a Hollow body, it is to increase the glue joint surface area for a more solid joint around the body edges. They put it on the fretboard too for looks, and looks ONLY. The fretboard doesn't need any help staying attached. When they started making solid body electrics, they put binding on it because they wanted to make it look "familiar". like the hollow bodies. People equated it with "quality", when it really means nothing like that. I think the binding tidies up the seams between pieces of wood that are joined together. The seam between the mahogany body and the maple top being one example, and the seam between the fretboard and neck being another. As protection, it's arguable. For me, the top edge of the head stock north of the third set of pegs is what I'm most likely to ding or dent. Neither of my guitars with a bound headstock have any dings where those surfaces are bound. For that matter, none of my bound body guitars have dents or chips along the bound edges. I think the binding helps.
DavesNotHere Posted August 20, 2015 Posted August 20, 2015 Sometimes it's nice to have some binding and nice inlay done... Showoff
