Humbucker ID help?
ch99
I am new to humbuckers...is there a way to ID the Schallers, HRW, Seth Lovers, etc., other than opening them up?  I am looking at photos of a Heritage 575, from late 2002, and it has pups with the two screws on each side.  I think most pics of the HRWs show two screws, but I am no expert; maybe others pups use two as well?
Forgot to mention ...
If you are in contact with a seller you could ask them to take a close look inside the f-hole with the label in it, it often has the pickup model written on it along with the finish.
For example "59s" would indicate Duncan '59s.
The Schallers usually have a total of 4 screws per pickup, 2 each side, Duncans normally have a total of two per pickup ... one each side.
Hope this helps.
If it's listed as a "Classic" model, then it will have the Seymour-Duncan pickups in it, either the '59s or Seth Lovers.
