Scored at GC
samwheat
I bought a used Laney Pro Tube 100 for rebuild into a Frehley Alive II amp. I replace the board, OT, caps and put a white plexi faceplate on it. Its already drilled for the 4 hole inputs. $312 shipped for free to the local store. I took the panel off and there are 4 Tungsram ECC83's and 4 Siemens EL34's in it. Money well spent. Now all I need is a quad of GE 6550's.
I have a 1987 with 6550's in the room with me hooked up to music for break in of the sozo caps. That too is a butterfly from the Laney caterpillar.
What? ........................ :)
Don't know much about the amp, but I know enough about tube names that it sounds like you scored pretty well.
