H150 with custom ebony Fretboard and korina ?
hopkinwfg
wonder would Heritage do a slight custom H150 with an ebony fretboard, one piece Korina body and a korina maple multi laminate neck, a solid big leaf curly maple "checkered" ?
They've done those super special (aka expensive) guitars before. Ed Roman had a special run many years ago.
Here's an example of a Korina back/neck with a Quilt Top that belongs to HOC'er 'zbluesman':
The checkered look you are talking about is a tight flame that is book matched and layed out straight across the top with prominent grain stripes from a perfectly quarter sawn piece of maple. You must specify it being perfectly quarter sawn and the flame to be absolutely perpendicular to the grain. Big leaf will probably not give that type of tight flame it usually has a larger flame and often very quilted. The softer maple tend to be bigger flame and more quilted. The harder maples tend to be tighter flame and the grain tends to show more too. The Ray cells show more on hard maple too that is perfectly QS. Hope that helps.
very similar to the Class of 59s, They work with Korina, Marv does a bunch of 357 builds, the top would be classified as an Ultra top ($500)... I specifically asked for a 3 piece neck on a personal guitar and was steered to go 5 piece.
Someone mentioned expect to pay a premium... current Solid Black finished 150's with case are MRSPing around $3400 plus upgrades it could be a pricey build.
Aside from the neck I believe everything should be available without problems, slight time delays for the Korina,... by the way, I asked for ornate Black Korina which seems very difficult to locate these days!
One time I asked for a quilted Maple top on a H150 and I was told that it might be a year or more before they would be able to source a piece of quilted Maple. Something like that you might find yourself waiting longer than they will be in the guitar business.
wow..... thats really steep ! maybe a solid top would be really out of my picture here... maybe a closely matched be good
You couldn't touch a Gibson custom order anywhere near that. Expect to pay 2 to 3 times a much to order one through Gibson.
thx and yup your right... gibson is overpriced for what they are doing now... more of quality over brand thing...
i been gassing this for long time but am afraid am not a LP guy... :(
Quotes don't cost anything. Would be interesting to see first, what Heritage says about the build. Second, what they say it'll cost.
That type of flame is hard to get, mainly because the "flame" process usually distorts the grain lines. It has to be a particular cut for it to appear that way, and it can be hard to pull off.
That's quilted maple
