holyroller Posted March 28, 2016 Posted March 28, 2016 Trying to figure out how the 4 mini toggle switches work on a heritage stat . I know that in the up position they work . But what's powering the pickups ? You Sent from my iPhone using Tapatalk
mars_hall Posted March 28, 2016 Posted March 28, 2016 Coil tap on bucker and on/off on all. A wire moving through a magnetic field will cause electrons to flow in one direction if there is a complete path (circuit). Direction of flow will change as the string changes its direction through the magnetic field.
holyroller Posted March 28, 2016 Author Posted March 28, 2016 When all the switches are off nothing works the toggle closes to me doesn't make a sound even when it's on. I know it's probably easy but just figuring it out , Sent from my iPhone using Tapatalk
