Switch gone bad-Boss DD-3
Anybody ever had a switch go bad in a Boss effects box? When I depress it, the check light comes on but goes out when I release the pedal. I am thinking the switch went bad. I wonder how good their support is. Will find out tomorrow I guess.
That's the reason I've stopped using Boss pedals altogether. I've had far to many of them fail and it's always the foot-switch.
Yep a switch on a pedal is like brakes on a car in my opinion. are open to the environment so that dust and crap WILL get in there. They get stomped on regularly. They're cheap and easy to fix/replace. I don't consider a testament to the pedal, unless it happens in the first year or so with light use, then you probably got a bad switch. take 20 minutes to address, and play in peace for X more years....
  • 2 weeks later...
Kip, are the replacement switches easy to obtain?
Click on Grambo150's link. If you can follow directions, you can clean it, or order a new switch from the link at the bottom.
