FredZepp Posted September 17, 2016 Posted September 17, 2016 ... yes, that legendary rock n roll mike. I thought this was an interesting link about the venerable Shure SM58 . http://blog.shure.com/10-things-might-not-know-sm58/ My current favorite mike is a Beta 58A
111518 Posted September 18, 2016 Posted September 18, 2016 Yes, interesting stuff. I've discovered that the "look" of the sm58 is almost as powerful for young vocalists as the look of the strat and paul are for young guitarists. In equipping the student ensemble that I direct, I've purchased a number of mics, often with the strengths and weaknesses of particular vocalists in mind. So, I've tried to use several models of Audix vocal mics, and Senn 835's and 945's( a mic I like a lot.) All of these "non58's" have significant spec/pattern advantages over that old Shure warhorse, but, when I put mics up for young vocalists, they go to the 58's, and avoid the others like the plague. And, forget about explaining to them the 57 is the same mic with a different windscreen. Sing through an instrument mic? Never. In this context, the big advantage of the Beta58 is that the students can't tell it apart from the sm58, and will actually use it.
FredZepp Posted September 18, 2016 Author Posted September 18, 2016 On 9/18/2016 at 12:33 PM, 111518 said: Yes, interesting stuff. I've discovered that the "look" of the sm58 is almost as powerful for young vocalists as the look of the strat and paul are for young guitarists. In equipping the student ensemble that I direct, I've purchased a number of mics, often with the strengths and weaknesses of particular vocalists in mind. So, I've tried to use several models of Audix vocal mics, and Senn 835's and 945's( a mic I like a lot.) All of these "non58's" have significant spec/pattern advantages over that old Shure warhorse, but, when I put mics up for young vocalists, they go to the 58's, and avoid the others like the plague. And, forget about explaining to them the 57 is the same mic with a different windscreen. Sing through an instrument mic? Never. In this context, the big advantage of the Beta58 is that the students can't tell it apart from the sm58, and will actually use it. Ha, I would have guessed that this would be true more of my generation than your students. The folks at Shure have to be happy about this. It may be why I like the Beta 58 also.... hadn't considered that.
tulk1 Posted September 19, 2016 Posted September 19, 2016 Happy Anni to the Shure, for sure. But we dumped our SM58s years ago. First went with the Senn 835s ( I still use mine on acoustic gigs). Tried some Blues. Now we've settled on the Audix mics. For us, just easier to EQ - actually less eq'ing. Even years ago I was not fond of the '58s, but they were what was available and the "IN" mic. I've played with two other bands where the vocalists used the Betas. They sounded nice!
t0aj15 Posted September 19, 2016 Posted September 19, 2016 I used the SM-58's going back to the early 70's but recently switched to Blue Encore 100's. I'm glad I did, they sound better at a better price. http://www.sweetwater.com/store/detail/enCORE100
