575 setup tricks
minug
Hi all,
I just cant get my 575 to play the way I like it. Any setup tricks or procedures? The neck is just about straight buzzing continues. Any help would be appreciated.
All kinds of things could be wrong... The nut might be worn out, how old is the guitar? The bridge might have collapsed, are the strings touching the back of the bridge? There could be an errant fret, how dry is the fretboard?
We're going to need pics.
When he was six, he believed that the moon overhead followed him... by nine he had deciphered the illusion. Trading magic for fact, no tradebacks. So this is what it's like to be an adult. If he only knew now, what he knew then...
Without an in-hand examination of your 575, all we can offer is suggestions. It could be a number of issues, or one simple adjustment. If you've tried all that you know, it would be worth it to have a pro check it out. I do most of my own set-ups, but I took my 575 to a luthier to maximize its playability and have no regrets.
Good luck.
Time for a pro. My H575 played rather well, a little buzzy, but I suspected could do better. took it to my very talented luthier buddy, who did a most thorough setup. Levelled frets, tweaked the truss rod, fussed with the nut string slots. So much better, well worth it.
MD
Or, raise the action a little, not much to lose as you will probably be bringing it in anyway. Does it buzz on the open strings? That would be the nut. As said a good set up is worth the outlay.
