Needa boost......
I've just ordered a new amplifier and the one thing that it doesn't have on board is a boost/solo function. Well, I certainly need one for lead work.
I have an MXR Dyna/Comp and a CAE Line Driver. I plan on putting it last in my effects loop.
However, I've also been looking at the TC Spark, Xotic EG Boost, and the MXR Micro Amp.
Primarily, I'm looking for a push in volume with little coloration.
Suggestions?
Sent from my SM-N920V using Tapatalk
I don't use a boost any more. I just crank the amp up a little and use a volume pedal.
What amp did you order?
Orange Rocker 32.
Thanks to all that have replied. It makes for good research via YouTube.
The volume pedal may be a good idea. In the past I've had to wedge the footlever in a particular spot. So it wont do a full sweep. Either at my rhythm level or wide open for leads. Seems I'm too clumsy to properly operate one. LOL!!!
Think I'll try the Line Driver first before I make a solid choice.
Thanks again everyone.
Stupid phone!!! LOL!
So, thanks for all of the research material. It was cool.
I ended up putting my CAE Line Booster last in the chain within the effects loop and it works like a champ. Kinda cool, because now I can search for an overdrive pedal to run on my clean channel for that in between drive sound.
Thanks again!
  • 2 weeks later...
A bit off the beaten path. Port City Salem Boost. Most effective, transparent clean boost on the planet, period.
