thmsbp
I have a 1998 535 and was wondering if anyone knows what pickups are in it. They are stock. I didn't know if they used their own pickups at that time or not.  Thanks!.
How many screws on each side of the pickups at the rings?  If they are two on each side, you have Schallers.  If not, you may have to remove the strings and check the backside of The pickups.
2 each side could also be HRW pickups,if so there will be a black dot on top of the pickup selector switch.
Here is a pic of my '96 535.  I don't own it now.  It had Schallers in it.  Note the two screws.  Very decent pups.  Make you amp do it's work.  ;^)
I have a 2002 with stock Seth Lover, mine also is written on the Heritage tag inside the F hole.
