Bridge pickup?
big bob
So I’m playing my super cool custom prospect, just jamming it out when the keyboard player says “hey can someone help me with bring in the pa”. I’m a good guy so I say sure. I put the amp on standby and lend a hand. When I come back I switch on the amp and get no volume? I check all the cords and long story short the bridge pickup has almost no volume at all. If I crank the amp up to 6 I get a real week signal. Everything else works fine. Neck pup, neck pup + bridge has no volume loss?
Lollar dogear p-90s
Get a multimeter and check continuity through the pickup.   Either a cold solder joint broke loose, or you developed an internal short.   I would guess the former.
Cold solder on the pup or the switch?
Prospect has no control access execpt the f holes and the binding makes it real tight!
thanks
Plug a cable in, switch to the pickup and read the resistance (volume wide open).   If its near zero, you have a short, if its got an open spot, you'll see very high resistance.
You might try moving the wires around on the harness.   When I was rewiring my 535,  I used the vintage braid wire, and somehow, the ground braid managed to hit the tab on one of the pots and the pickup went dead.  Pulled the harness and everything read fine.   I put shrink tubing over the cable to prevent that from happening again.
PS,  I would be glad to come down and do the rewiring.   I'll only charge you $150/hour plus travel expenses.   Oh yeah, when I rewired my 535 it took me something like NINE hours.  You might have a nice bottle of bourbon there as well, just to calm me down when I have to take the harness out AGAIN!  :hissyfit:
Expand
Yeah yeah, you ain't never comin to Florida I can guarantee that one!
agree with Rich: I bet you have some crossed wires in the controls grounding out, or maybe a wire came detached from a pot?
wiggling the cables around inside might get you some sound?
or a dental mirror + light could give you visuals
good luck!
I sometimes have a connection problem with my wiring to the bridge pickup coming loose on my prospect and if i stick my hand in the f-hole and jiggle it, it re-connects.  I've been too lazy to have it professionally repaired.
Expand
The bourbon's likely why it took nine hours....
Expand
Hahaha...
