Heritage H158 Millennium Classic Bigsby Woes
tbonesullivan
Many may remember my H-158 Millennium from past postings and a PSP or two. Well, one thing that has always been less than ideal for me is the functioning of the Bigsby, as well as tuning stability.
Now, I know that no matter what I do, it's never going to match the likes of a modern 2 point trem.  However I think it still can be better than it is now. It came with the Licensed B50 overseas made Bigsby, which uses nylon bushings for the roller joints. The original Bigsby uses captured bearings, which can be oiled and maintained. So I'm looking into the possibility of sticking a B5 on in place of the B50, as well as having a new nut installed, optimized for tremolo use. It still has the stock nut, but I don't feel that it's as well cut as it could be, and doesn't have the flat bottom string slots cut that you'd usually want on a tremolo guitar. So also getting that re-cut would be on the list of things to do.
I LOVE the guitar. The sound is incredible. I'd just like to make it MORE incredible by having a more functional Bigsby. I've always felt that Licensed bigsby has too much slop in operation.
I'm sure you know this, but just a reminder, Graphite grease on everypoint the string touches can't hurt. I do that on all my Gretsches and it really helps with the tuning! And the idea of recutting a new nut is a good one, especially if you put a graphtec on on there which seem to help with problem guitars. I've never been a fan of those roller bridges but others seems to like them. Good luck sorting your issues.
I've seen tutorials where people coat the entire bottom of the tensioning roller with grease, kinda like how people would coat the top of a kahler with chap stick.  I've also heard some say that the licensed and the original are pretty much the same, and others say that the original is far superior.
can't hurt!
I don’t have any problem with mine. 3 hr gig no issues. Mine are all USA, graphite nut, roller bridge. Maybe you could add locking tuners?
Came stock with Sperzel locking tuners, Schaller locking bridge.  The problems seem to stem from either the nut, or the bridge. There are some mods that can be done to a Bigsby to make it more "Friendly", but all of those only apply to the USA B5, which has the actual oiled bearings, and not just nylon bushings.
Nut is an easy replacement. I’ve really not had any tuning problems with any of mine. Maybe I’m just not that observant.
5 hours ago, skydog said:
Have you tried the Reverend “soft touch” spring mod?
http://store.reverendguitars.com/product/soft-touch-spring/
The problem is more related to the strings not returning to pitch after using the vibrato, and possibly even after bends.   I'm going to start out with oiling the bigsby, and also putting some graphite in the nut slots to see if I can improve things.
7 hours ago, bolero said:
good luck, that is a great looking gtr!
It really is. I need to bring it back out of the case. It needs to be played.
