In praise of the 535
Cajun2
I've gotten pretty good at holding the string under tension with one hand, while using the other to tune up
but both of those options sound pretty useful
one of these wedge shaped ones would be ideal I think:
Rockabilly, do you need to remove & reapply the capo, for every string? i guess you would...
  • Replies 52
  • Created
  • Last Reply
I bend a slight hook at the ball end of the string,  then I use a small piece of packing foam or styrofoam under the pin to keep the ball end from falling off.
I was initially scared to get a Bigsby equipped guitar because I heard how hard it was to change strings.  It's not hard at all.
On 12/19/2019 at 11:26 AM, rockabilly69 said:
pretty much the reason I came up with the capo trick:)
We live and learn Daniel-san.
