reviresco Posted February 9, 2020 Posted February 9, 2020 Hi everyone. Does anyone know if the new Heritage Guitar’s are Plek’d the way Gibson pleks or are they done on a Plek Pro machine? As I understand, Gibson only uses simulated tension and does not account for neck relief. I also understand they do the Plek before the guitar is finished and stung up. It is done under simulated tension. Wondering if Heritage uses the Pro process and how good the Plek work is. Thanks for the help!
tulk1 Posted February 10, 2020 Posted February 10, 2020 On 2/10/2020 at 3:14 PM, mars_hall said: They are strung Expand Mark, how can they be strung and then plek'd? Doesn't the pleking take metal off the frets? Would seem counterintuitive to string them up first. Then again, maybe I don't fully understand the pleking process.
Steiner Posted February 11, 2020 Posted February 11, 2020 Guitars are strung, fixtured then measured. If necessary the trussrod is adjusted and the process begins anew. Then the guitar is unstrung, refixtured and measured. From that point the computer program makes inferences on how to alter the frets and machining begins. If done correctly, the guitar is restrung, refixtured and remeasured - That takes time and effort. It additionally indicates the errors in fixturing and the machining process...
reviresco Posted February 11, 2020 Author Posted February 11, 2020 Here is the response I got today from Heritage. “Thanks for writing in. For our Standard H-150s, we PLEK in whitewood (before paint). This helps us in a couple of ways. One major benefit is quality control for the necks/neck pitch/frets. The PLEK catches flaws and we can act quickly if something is found, which helps us not waste time or lumber. There are always exceptions. After PLEK and during paint we do more work on the frets and then again in final setup. A PLEK is never enough since the frets still need to be polished and looked over to make sure the machine didn't make an error. Finally, we don't batch PLEK. We do them individually. That may be a difference but I'm not sure what others do.”
DetroitBlues Posted February 11, 2020 Posted February 11, 2020 Either way, I have a couple guitars that were Pleked either by Gibson or aftermarket. Its a good baseline process for fretwork as indicated above. But there still is a human element required to make sure its right.
Steiner Posted February 11, 2020 Posted February 11, 2020 On 2/11/2020 at 11:25 AM, DetroitBlues said: Either way, I have a couple guitars that were Pleked either by Gibson or aftermarket. Its a good baseline process for fretwork as indicated above. But there still is a human element required to make sure its right. Expand +1 Wait, your button has been erased...
Spectrum13 Posted February 11, 2020 Posted February 11, 2020 On 2/11/2020 at 12:25 PM, Steiner said: +1 Wait, your button has been erased... Expand Just like when the mileage on an odometer exceeded available digits .
stormymonday Posted February 13, 2020 Posted February 13, 2020 my ES-335 Studio came plek'd from Gibson. Still had to do some setup.
Millennium Maestro Posted February 13, 2020 Posted February 13, 2020 Plek is a tool, A guitar is made of wood... Take that instrument into a different climate and it adjusts. I believe a guitar should be used and worked with in its own environment for a few years... I have seen many Gibson Pleked guitars that have frets that need attention. My first preventative maintenance is to give a really good mineral oil to the fingerboards upon taking possession, I see a lot of dry fingerboards leaving manufacturing warehouses.
