Prospect Floating or Fixed
ficecone
How can you determine if a Prospect has the fixed or floating block?
Thanks
Look at the bottom of the block, you should see about a 1/4 inch space between the block and the back of the guitar.
Prospects are awesome.
15 hours ago, DetroitBlues said:
By original design, always floating.  There can be cases when they aren’t, but pull out a pickup and take a look under the hood.
You can probably see the space just by looking through the f-hole.  I have one of each (solid, floating and full hollow). Solids sound pretty similar to a 335, but the floating and full hollow definitely sound different.  I would suggest going with a floating or full hollow (but those are hard to find).
