Prospect Floating or solid? Can anyone I/D these pics
ficecone
I pulled the pickups on my prospect to try to figure out if its solid or floating but I have no idea what I'm seeing in the photos. Can anyone help? Floating or solid?
Thanks
If you look in the f-hole, you will get a side perspective, and you should be able to clearly see if there is a space between the block and the back of the guitar.   You may find inserting a small mirror in the f-hole, at an angle, helpful.  If there is a space, it is floating.
Take it to a natural body of water.
Remove it from the case.
Toss it in the water, if it floats then it's a witch and burn it ?️ before your turned into a newt.
Hahaha!
