1 man 2 h-160v
Perilmeglio2
Finally...i did it!
I found my 2nd H-160v!
As you can see is quite different from the one I already had (on the left): the body is clear while the other is almost cream, and even the fretboard is darker.
The other one has a hb SD Jeff Beck, this one is totally original!
I just wanted to show you my new toy... ?
If your new H160v has the serial number, C 08603 which means it was built October 6th 1986, I used to own it.
It has been refetted and PleKed to perfection. That's a Fab guitar.
Good times.
2 Rare Beauties. Congratulations!
35 minutes ago, Perilmeglio2 said:
E serial both, same age of production.
The "cream one" is always on a stand and is often played, the "white one" I guess has passed most of its life in a closet
They really are twins!
I guess I am a little confused. I have what I think is an H-160 (fire engine red!) but it has the traditional strat five way switch. My Stat has the four mini switches like you H-160. So is mine just a later version?
If I'm not wrong h-160v and Stat are different models, both have a "strato" shape but they are different.
From my research it seems that only 20 h-160v were made... so I had 10% of the world production of this model ?
Hey, thanks....mine must be an H-162. It has the pointy headstock and the strat style 5 way switch. It is really light so it must have a poplar body with a Kahler trem.
My Stat is a super strat style but mahogany body and maple top with binding. It has the 4 mini switches for the pick ups and set neck.
Interesting....my H-160 has a serial number of E20207. They must have been building them at the same time. I thought they may have developed them over the years....like I said, mine has the 5 way switch and also a maple  fretboard.
Never even knew this model existed!
