Chicken head knob removal advice needed
ElNumero
I have a 20+ year old Peavey Classic 50, wonderful clean amp, sounds great still after all these years. However, when I turn the channel volume control the amp cracks and cuts in and out. If I find a position where it is working I leave it there, however if I adjust it, the amp will cut out almost entirely. I suspect it needs a good spraying. Which leads me to this question: how to safely lift and remove the chicken head knob to get into the shaft. There is no set screw, but that baby is on there tight! I just do not want to damage the faceplate or the shaft prying it off incorrectly.
Try working the amp's knob high to low, multiple times.  Generally, the sealed pots have a lifetime of dielectric grease.  You just need to work the knob to redistribute the grease.
I did do that a bit, but perhaps not enough. I'll work that knob back and forth until it screams for me to stop!
By the way, ever heard Mike Campbell's band, The Dirty Knobs?
What Steiner said.
Though you still fell compelled to remove the knob; I usually take a microfiber cloth, or some other thin cloth like material, slide it under the knob, then sort of wrap and use the towel to pull it off. If not enough clearance for that, a piece of yarn/string would be my backup plan.
My parting note - if it's not a totally sealed pot, then usually you can work in some deoxit stuff from the backside around where the wiring terminal lugs reside. (disclaimer: make sure amp is off and caps are discharged).
2 hours ago, kbp810 said:
What Steiner said.
Spot on Brian.  Couldn’t have said it better myself.
Spraying from the back of the pots definitely does get much better coverage of the wiper and conductor.
They do make adapters that help the spray get into the pot better. It pretty much screws onto the pot and has a hole where you plug in the plastic tube.
Also, make sure the pot shafts are pointing upward if you are spraying the shaft end. Gravity does help.
34 minutes ago, bolero said:
Cut it off with an axe & let the amp run around uncontrollably for a while
Sometimes, the easiest solutions are the best...
You made the Mt Dew come out of my nose..... you bum!  :P
I don't understand...........................is this a Canadien thang?
I think I will stick with your solution.
no, more of a rural/farm joke....if anyone has ever cut the head off a chicken, with an axe, you might get it ;)
An awesome crack, even if I do say so.
+1
+1
Some crack is awesome, other crack is not!
Tis but a bout of humor.  What happens when you cut da head off da chicken, eh?
I would leave the knobs alone...
remove the chassis and hit all of the pots from the inside properly with a good contact cleaner / lube.
FWIW I have been using Nutrol for decades.?
I'll be!  Will, as many chickens as you have choked I figured you had that down.
