Millie pickup question
titojams
If you have the guitar loosen those strings and pull one. Yooper is correct, probably Schallers. What is the letter at the beginning of the serial number?
They are most definitely Schallers of some sort, you can tell by the dual height adj screws.
AFAIK no one elses uses those. They are a great idea, as you can fine tune the angle of the pups to match the strings
7 minutes ago, Millennium Maestro said:
I would say HRW with new toggle tip. I don't ever remember seeing Shaller in the Millie series. Is that the one from GC from a few months ago... That had HRWs it was on the build sheet inside the F hole.
Yes, that’s the one. I thought I could see that on the tag.
Good call, Guy.
