NAD Paisley Blue Sierra PRS
greywolf66
I've enjoyed my DG30 custom so much  I was looking for another of Doug Sewell's masterpieces .  The Blue Sierra was one of the initial models from PRS Custom Amp Dept . This is the model Derek Trucks plays .  50w hand wired EL 34 ( can run 6L6's) with a 2x12 that has seperate jacks (custom) so you can run it as a single 12 /share the cab with another amp or run both ..  Just love the Paisley ...
Well, if it sounds as good as it looks, should be a winner! Interesting setup on the cab with being able to run as single or pair.
Doug Sewell is obsessed with tone and has the freedom to chase it
Gorgeous!
I think I've played through one of those. Does the back of the speaker cab have an oval cutout?
The Blue Sierra is a close back , it just arrived  ...VERY clean Texas  blackface Super Reverb tone  if you plug straight in . Much more sparly than the DG30 , as Grissom doesn't like bright amps as he's a bridge pickup guy
Oh! I think the one I tried was a 60s Marshall based. In any case, that is beautiful!!
Congrats
If you keep the Master low and dime the volume you get outrageous thick fuzz , bring the master up a bit and it gets ferocious.
For the Curious the pedal board : Xotic Sweet Sauce booster->Fender MTG Tube Distortion (old school) -> Keely Dark Side->Boss Auto-Wah -Keeley Hooke Reverb-: TC Stereo Chorus/Trem/Flanger -> split path 1 DG 30 / path 2 Trex Quint octave pedal set with 50% 1 octave down, 25% 5th to Blue Sierra
Very fun to stack the gains of the first 3 stages as the Dark side has a wicked fuzz I have set to full range (vs scoop /flat) .. Santana in a box at bedroom volumes
It also has phase/univibe/flange/leslie/delay that are quiet fun , the Hooke has Univibe/reverb and Trem /verb settings .. stacking the univibes is wild!
Kick in the quint ( which I typically use for fiddle to add "reediness) and it sounds SO wicked.
Thanks folks , had a local artist play through it and the smile would put a chesire cat to shame .. She loved the H535 through it.
Yes Bolero , The Dark Side fuzz on the right side  ( Flat/Full/Scoop toggle)  on the other side  it has Flange/Rotary   Delay   and Phaze / Univibe.  The DG30 loves the overdrive pedals , the Blue Sierra has so much gain they are completley wasted.
The rotary switch goes from one effect to the other for the dual sounds, in the middle you get a bit of both ... a very cool pedal .   Stacked univibes  ( with the Hooke ) is just cool 4 days    there's a button up top if you run both effects you can chose fuzz pre or post
  • 4 weeks later...
  • 2 weeks later...
