Tributes to my Guitar Heros (pics)
Kuz
Sean Costello and his '56 LP GT p-90s
Kuz's "Sean '56"
Peter Green and his '59 LP with magnet flipped neck pup
Kuz's "Greeny '59"
Whenever anyone asks me to recommend some gut crunching, heart breaking blues/blues playing, I always refer them to Shrine 69.  And, btw, that is a beautiful guitar.
why flip the neck pup.. just courious..
Flipping the neck pup itself does very little (maybe a slightly brighter tone), but most flip the magnets inside the pup and then turn the pup around to get an out of phase sound when in the middle position. For example, Peter Green & BB Kings' tone.
John, did you have the magnets flipped, then? Or just the pup?
You only have to flip one pups magnets to get them out of phase (and I did in the neck pup). If you flipped both then they would be like a regular guitar with both in phase.
The out if phase only occurs with both pups on (middle position). To be honest, I don't use it that much. It sounds like a Strat in the 4th postion (neck & middle) except a little more extreme. You can roll it off a little though.
Hey, it helps to justify why I have 2 150s with humbuckers. But then again you would understand that with your 2 Millis!!! :P ;D
is that a five way toggle, how do you get 4 positions?
Three way toggle like a normal 150- the middle, both humbuckers position, just sounds like something like the 4th position on a Strat.
Bob, you don't get 4 positions. John was saying the middle position sounds like a Strat in pos 4 (neck/mid out of phase), but stronger. That is something I could actually use, as I use pos 4 on my Strat probably more than any other.
Ooops, I see John already answered.
John,
That's one fine top you got there.
  On your P90 Gold Top...  Did you put in the Lollar 53s designed from Costello Pups?
  Also I understand Heritage is now using CTS pots instead of the WD, have they got brass shafts and 500 V & Ts?
John,
Honestly I don't know what that other tech stuff means, but as far as the Lollars. I called Jason and we talked about the Sean Costello lower wind p-90s, but I LOVE the way the regular winds sound. All three of my Heritage p-90s just have the regular Lollar p-90s as far as I know.
P-90 Eye Candy...
  • 5 months later...
