tsp17 Posted March 22 Posted March 22 i’ve always heard that amp wattage and speaker wattage capacity “shouldn’t” be too far apart. For a rough example and rule of thumb (subject to what you like to hear) a 35 watt tube amp would call for a speaker capable of 50-75 watts. just my non-tech understanding of the prevailing view. I have multiple amps mated to speakers (either in combo or cabinet) that will take up to 250 watts. I have a 2x12 cabinet with a pair of 250 watt 8 ohm speakers that sounds amazing with a 50 watt amp. So what am i not understanding here? I just put the same 250 watt rated speaker in a 35 watt combo amp (3rd Power Wooly Coats Extra Spanky). Sounds pretty good so far (needs to break in). Very touch sensitive, but really good first five or so hours on it. Thinking about experimenting with something lower wattage. I’m a big believer in Duke Ellington’s saying that “if it sounds good, it is good”, but curious about what difference it might make to more closely match the amp wattage to speaker capacity, e.g., try a 60-70 watt similar speaker. thanks, Tad
kbp810 Posted March 22 Posted March 22 Eh, lots of variables and generalizations in play... but in a nutshell; if the amp wattage is higher than what the power/watt handling of a speaker is, it's going to lead to 1 of 2 likely outcomes - 1) the speaker will easily distort... which in some scenarios could be a desirable effect and compliment the amp distortion (especially when paired with another higher power/sensitivity speaker); in other scenarios, it could just sound muddy, "farty", or bad. 2) The speaker could just fail...blow the cone out or toast the voice coil. In the reverse role; if the speaker watt/power handling is way higher than the amp output... usually this will make very little difference. It depends more on the design and sensitivity of the speaker at this point. For example, I love to pair the 300 watt EVM-12L with all sorts of amps, including little 5 watters; fairly transparent speaker pairing that let's more of the amps own voicing be heard (minimal speaker distortion/coloration). Usually the only negative scenario is where it's a speaker with a very heavy cone and low sensitivity; that could be a speaker that needs a whole lot of power to make it move in order to sound good. There's not many guitar oriented speakers out there that fall into this grouping though. It's more in the extreme cork sniffers high end of car or home audio (or cheap garbage speakers from temu or something). TLDR - Low power amp with high power speaker; okay. High power amp with low power speaker; may cause death of speaker, or could get you that cinnamon girl sound you've been searching for all your life (if one was to ever search for such a sound).
TalismanRich Posted March 22 Posted March 22 The wattage on a speaker is an indication of how much power you can put through the voice coil without it heating up to the point that burns out. The suspension, cone material, available voice coil travel will determine if it breaks up, and sensitivity will tell you how loud the speaker will be at a reasonable power level. The speaker will distort if you exceed the rating, especially if you try to exceed the cone travel. If you play highly distorted, then you should have a higher power speaker capacity since those distorted squared off waves are actually higher in power than a sine wave of equivalent amplitude. Something like the Celestion Peacekeeper handles 50W but only puts out 86dB for 1 watt of power. A Vintage 30 will handle 60W and puts out 100dB for that same single watt. Also, it depends on where you set the amp. A Twin can put out a lot of power, but if you only turn up to 2, you might only be putting out 3 or 5 watts.
tsp17 Posted March 22 Author Posted March 22 thanks guys. I knew i was asking the right crew. much appreciated.
bolero Posted March 22 Posted March 22 yep summed up pretty good above There is a dynamic between particular speakers & particular amps. Always good to play around with combinations but use caution. Unless you can afford recones or don't have any rare vintage speakers. I have an old ~15w tube amp I put an ancient Bell & Howell alnico film speaker in it, very light resonant cone. That thing RAWKS when it's cranked up. I bet it's just on the verge of the speaker's power handling
bolero Posted March 23 Posted March 23 man, I was just thinking about this thread again. I wish I still had my celestion alnico blues & alnico gold 12" speakers. They were really good. I sold them when I unloaded my Vox & Matchless amps
tsp17 Posted March 23 Author Posted March 23 16 hours ago, bolero said: man, I was just thinking about this thread again. I wish I still had my celestion alnico blues & alnico gold 12" speakers. They were really good. I sold them when I unloaded my Vox & Matchless amps with you there my friend. my list of things that I wish I'd kept, or should have snagged, lives in my head rent free. very happy with what I have now, but there a few items that in hindsight ....
rockabilly69 Posted March 24 Posted March 24 My favorite speaker is the Weber 12A125A. It's a low wattage speaker that I use in three amps currently Mesa DC-2 (25 watts) Clark Beaufort Supreme (20 watts) TopHat Club Deluxe (20 watts) The speaker is rated at 30 watts, but sometimes I throw a lot of outboard gain pedals into these amps (Origin Effects Revival Drive and M/EQ driver, Analogman Sunface BC108 fuzz, Durham Sex Drive) so I try to listen carefully to see if I'm at that edge. Because as Rich says above, square waves (particularly fuzzes), can destroy speakers if pushed close to their ratings! That said, I WANT the speaker to distort as I think that is part of the rock and roll sound.
tbonesullivan Posted March 25 Posted March 25 4 hours ago, rockabilly69 said: That said, I WANT the speaker to distort as I think that is part of the rock and roll sound. Guitar speakers are definitely designed to have a "non-linear" response zone, and they do break up when pushed. How much they do has to do with the design, and also how much "dope" has been put on the cone.
bolero Posted March 25 Posted March 25 8 hours ago, rockabilly69 said: My favorite speaker is the Weber 12A125A. It's a low wattage speaker that I use in three amps currently I have one of those with a destroyed cone I keep forgetting about. I should get it reconed!
rockabilly69 Posted March 25 Posted March 25 6 hours ago, tbonesullivan said: Guitar speakers are definitely designed to have a "non-linear" response zone, and they do break up when pushed. How much they do has to do with the design, and also how much "dope" has been put on the cone. Mine are lightly doped and they break up gloriously. 3 hours ago, bolero said: I have one of those with a destroyed cone I keep forgetting about. I should get it reconed! yes you should!
tbonesullivan Posted March 25 Posted March 25 13 hours ago, bolero said: I have one of those with a destroyed cone I keep forgetting about. I should get it reconed! oh boy, is there a good story to go along with that? I've only once had to deal with a bad speaker, which came in a Rivera Pubster 25. The horrible wiring job should have been a clue, but man the frame was even bent. No idea how the person who sold it to me could have not been aware of that.
zguitar71 Posted April 3 Posted April 3 A speaker that is rated at twice the amp power rating has long been the safe standard, or the combination of multiple speakers equaling twice the rated power. I personally don’t think that is really necessary though. I have now built 3 6g3 amps and paired them with 65 watt Scumback M75 Speakers. I would use lower wattage but there isn’t one until you get down to 25 watts. The amps have varied in output based on the power transformer used and plate voltage supplied. The lowest wattage of the three was 12.9 clean and 17.4 cranked all the way up with 355 volts on the plates. That would be fine for a 25 watt speaker. The first one I built I used a vintage spec PT and had 440 volts in the plates which gave almost 30 watts when fully turned up, that would not be good for a 25 watt speaker. So from a manufacturing standpoint, a company would spec a speaker that can cover variations like that. Smaller builders may have much less variation or can even spec the speaker based on a single build. I’m comfortable with a speaker that is around 10 watts more than the amp is rated for something lower wattage like a 17 watt amp. I built a JTM 45 that maxes out at 42.78 watts (JTM 42.78?) and I’m comfortable using the same 65 watt M75 in that amp but I probably wouldn’t go lower than that. The last gig I used that amp on I had a 200 watt Eminence Em12n speaker and it sounded great, especially clean. There is zero speaker breakup but the dirty sound is just a little sterile compared to the M75 that gets a little breakup and adds some warmth to the sound. Some may prefer the 200 watt speaker though, to each their own. The amp has a master volume and I turned it down to the level the sound guy wanted, then when I got home I measure the output. I played the gig at 14.5 watts dirty and about 8 watts clean with a 200 watt speaker. 8 watts with an efficient speaker is louder than most people realize and with todays stage management makes amps like the JTM 45 obsolete without a master volume or attenuation. I have a 20 speaker that is going into yet another 6g3 variant I’m building only this is a single channel and uses 6k6GT power tubes and should max out at 10-12 watts and be perfect for most places I play.
Anthony Posted April 4 Posted April 4 I was contemplating running my 50W Marshall head through my 1961 Hammond (as a speaker cab). It has twin 12 in speakers but only about 15W. Probably won't try that now🔥.
tsp17 Posted April 5 Author Posted April 5 3 hours ago, Anthony said: I was contemplating running my 50W Marshall head through my 1961 Hammond (as a speaker cab). It has twin 12 in speakers but only about 15W. Probably won't try that now🔥. good thinking. lots of good folks on this forum ready to help…it has always been a good place that way.
pressure Posted April 5 Posted April 5 I've got a Fab 100 watt Mesa KingSnake combo that has a single 12" speaker and it works just fine. Amazing!
rwinking Posted April 5 Posted April 5 Not sure if this is a different topic, but why do 4X12 cabs sound louder? What is that relationship about? OR what about a 4X12 cab with high wattage speakers vs low wattage speakers?
bolero Posted April 6 Posted April 6 why do 4x12 cabs sound louder than what? a 1x12? seriously? more speaker surface area also improves bass response. That's why bass cabs can use a bunch of 10" or 8" ( or even smaller ) speakers. smaller speaker cones are also faster, so a big 15" speaker may have more bass than a 10", but is slower & less responsive. usually. Throw a bunch of 10" speakers in & they're faster, and have the same low end as a 15" speaker cabinet design is a whole other can of worms: ported, not ported, direct radiator, passive radiator, horn loaded, diimensions & size, shape etc all factor in
bolero Posted April 6 Posted April 6 speaker sensitivity is important too. A 102 dB speaker is going to be louder than a 90 dB speaker, with a given amp
zguitar71 Posted April 6 Posted April 6 If you have a 4x12 and a 1x12 with the exact same speaker used and they are running the same ohms (let’s just say both cabs are 8 ohms) then the volume will be close for both cabs. The sound will be very different though because of the big cab and all that surface area of the speakers. The big cab can keep the low end together and put out a lot of it. The 1x12 speaker is working 4x harder than any one of the 4 in the big cab so it will sound very different and have a harder time keeping the bass as tight as the big cab. Though the volume will be close to the same if not the same for both, the way your ears perceive the sound makes the big cab feel louder.
bolero Posted April 6 Posted April 6 well what is sound & volume? air pressure more speakers = more air pressure I'm not sure who downvoted my post, lol, but I thought it was informative. I apologise if I offended somebodies sensitivities.
Steiner Posted April 6 Posted April 6 10 hours ago, bolero said: well what is sound & volume? air pressure more speakers = more air pressure I'm not sure who downvoted my post, lol, but I thought it was informative. I apologise if I offended somebodies sensitivities. Agreed with both posts bolero. Fuggem if they can’t handle the truth. Who argues with physics?
kbp810 Posted April 7 Posted April 7 On 4/5/2025 at 11:43 PM, bolero said: Apparently that was me… but it wasn’t I who disagreed with you, it was my big dumb clumsy scrolling thumb that took the low road there. My apologies; was not intentional. This has been rectified and replaced with a much more appropriate up vote; my fingers will be punished to the fullest extent of whatever my imagination can come up with for a witty and clever finger specific punishments. On 4/6/2025 at 10:18 AM, Steiner said: Agreed with both posts bolero. Fuggem if they can’t handle the truth. Who argues with physics? My thumbs laugh in the face of truth and physics.
