Tone Pros part number?
gopeteygo
I'm getting a little buzz from the roller bridge on my  '92 150.  I've considered switching to a tonepros setup (bridge and maybe tailpiece) and while I'm at it, for the '04 535 as well.  I would hope to just "pull out it and pop 'em in."  This is something I've never done.  Any experiences from you fine folk?  Part # anyone?
i bought one from this guy
http://www.thegearpage.net/board/showthrea...hlight=tonepros
great deal but i had to switch out the tailpiece bushings witch was much easier than i expected and did not damage the guitar whatsoever.
I bought a Duesenberg aluminium tailpiece recently and the guitar technician  had to pull out the bushings,too. No big deal if you have the right tools.
we just dropped a small screw in the bushing hole and tightened the post down wich forced the bushing out... not the most technical of tools but worked like a charm  ;D
Matched Bridge & Tailpiece Sets
"LP" Series matching Bridge & Tail Sets to fit most guitars:
"LP" S02=TP6 Bridge and T1ZS Matching Tailpiece (US thrd),
Starting at $116.50
I believe that is correct.
Or, do what I plan on doing: I bought some small allen-head screws, and I'm just going to drill out my bridge/tailpiece, and then tap the holes to match the screw threads.
If you use that method it's usually a good idea to heat the bushing up with a soldering iron first. If there is any glue holding the bushing in that will melt it and make removal a lot easier and safer.
If it works, it works :)
FYI - After taking some measurements on my 535, that does appear to be the right part # for the set.  I found a guy on ebay who claims to sell these for 15-25% off these WD Music prices.  The complete set can be found here.
http://www.wdmusic.com/tonepros_standard_t...sts_nickel.html
I'm guessing that since my 150 has the same hardware, the same measurements would apply, hence the same part # would work.
Follow-up.  I just got the pricing from this guy.  WD Music charges $116 for a set of bridge and tailpiece.  He quoted me $95 shipped for 1 set and for 2 sets $180 shipped.  Looks like I'll be doing my 535 and my 150!  ;D
If you're interested in contacting him, let me know.
  • 1 month later...
I want to get a new Tone Pros bridge/tail piece in gold. Do I need the small post or large post? I am thinking small. Here is a link to what I think I need, let me know what you guys think.
I forgot the link in the last post. Here it is.
http://www.wdmusic.com/tonepros_standard_t...posts_gold.html
That would appear to be the right one nat120, at least that's the same size that worked for me. If you want to make sure just take the measurements. I took the strings off my 535 and measured it up but I don't think you would have to. Once I determined the measurements of my 535 I ordered 2 sets and they fit my 150 as well. It made a difference on both guitars but the 150 just came ALIVE! If you want the guy's email I bought them from you wouldn't be paying full price. There's a pretty decent discount available.
Actually you would have to remove the tailpiece to measure since you can't see the posts under the Schallers.
gopeteygo, I was also considering this for my 150. If you could e mail me the guys info I'd appreciate it.
So the bushings are included with the set?
