Metalhedgear Posted May 16, 2009 Posted May 16, 2009 Hello all! I'm new here and have a quick question. Is there a tool for looking up specs on a particular guitar by serial #? If so could I please be pointed in the right direction? I'm looking to sell my guitar but acquired it long ago with no knowledge other than it's a les paul cherry burst i believe? Thank You
mars_hall Posted May 16, 2009 Posted May 16, 2009 Metalhedgear said: Hello all! I'm new here and have a quick question. Is there a tool for looking up specs on a particular guitar by serial #?If so could I please be pointed in the right direction? I'm looking to sell my guitar but acquired it long ago with no knowledge other than it's a les paul cherry burst i believe? Thank You Best bet for date...use first letter of serial number Model number is inside control cavity label. http://www.heritageownersclub.com/info.htm
Metalhedgear Posted May 16, 2009 Author Posted May 16, 2009 mars_hall said: Best bet for date...use first letter of serial number Model number is inside control cavity label. http://www.heritageownersclub.com/info.htm Thank you very much!
Thundersteel Posted May 16, 2009 Posted May 16, 2009 Yours was made April 13, 1998. It was the 6th guitar built that day.
Metalhedgear Posted May 17, 2009 Author Posted May 17, 2009 skydog said: ^^^ Heritage doesn't/didn't make a Les Paul. Thanks, do you know what the style is called by heritage then, if not a "les paul"?
JeffB Posted May 17, 2009 Posted May 17, 2009 Metalhedgear said: Thanks, do you know what the style is called by heritage then, if not a "les paul"? Post a pic. Either an H150, H157 or maybe an H140 if its slightly smaller.
big bob Posted May 17, 2009 Posted May 17, 2009 take the back plate(contro cavity)off and look at the sticker, It will tell all..
JeffB Posted May 18, 2009 Posted May 18, 2009 big bob said: take the back plate(contro cavity)off and look at the sticker, It will tell all.. Doh.... Thats probably easier
