What's wrong with my neck?
Dick Seacup
In all seriousness, do you wash your hands before you play. The other question, do you drink when you play, I do! when you play you sweat and when you drink it can exit the body in the form of sweat. Sweat
Perspiration (also called sweating or sometimes transpiration) is the production of a fluid, consisting primarily of water as well as various dissolved solids (chiefly chlorides), that is excreted by the sweat glands in the skin of mammals.[1] Sweat contains the chemicals or odorants 2-methylphenol (o-cresol) and 4-methylphenol (p-cresol), as well as a small amount of urea.
In humans, sweating is primarily a means of thermoregulation, although it has been proposed that components of male sweat can act as pheromonal cues.[2] Evaporation of sweat from the skin surface has a cooling effect due to the latent heat of evaporation of water. Hence, in hot weather, or when the individual's muscles heat up due to exertion, more sweat is produced. Sweating is increased by nervousness and nausea and decreased by cold. Animals with few sweat glands, such as dogs, accomplish similar temperature regulation results by panting, which evaporates water from the moist lining of the oral cavity and pharynx. Primates and horses have armpits that sweat like those of humans. Although sweating is found in a wide variety of mammals,[3][4] relatively few, such as humans and horses, produce large quantities of sweat in order to cool down.[5]
Metabolism is the body's process of converting ingested substances to other compounds. Metabolism involves a number of processes, one of which is referred to as oxidation. Through oxidation in the liver, alcohol is detoxified and removed from the blood, preventing the alcohol from accumulating and destroying cells and organs. A minute amount of alcohol escapes metabolism and is excreted unchanged in the breath, in the sweat and in urine. Until all the alcohol consumed has been metabolized, it is distributed throughout the body, affecting the brain and other tissues.
Try cleaning it with lighter fluid...no joke. The microfiber cloth wipedown is not nearly as good.
Hrmm, there is much potential in this solution.
had that prob w/my '98 LPC. took it to Kent Perkins, luthier & ace Heritage-enabler, and had him strip the back of the neck & put on a satin finish. no prob now. maybe someone near you can do the same...
:eek:
a little baby powder in the palm of your hand works wonders.
Especially great for outdoor summer gigs.
Keep a small bottle in your gig bag.
