Salutemysolution Posted October 28, 2009 Posted October 28, 2009 Does anyone know what kind of undertaking it is to remove the chrome cover from a set of humbuckers? I was thinking of taken the covers off of my 59s. I know they are wax potted so I don't know if that would make it a messy situation. I just like the look of the open black humbuckers as oppose to the covers.
Thundersteel Posted October 28, 2009 Posted October 28, 2009 I use a soldering iron with some solder wick to remove the solder. The cover should come off easily. Make sure the cover doesn't catch the windings when taking it off.
Salutemysolution Posted October 28, 2009 Author Posted October 28, 2009 I use a soldering iron with some solder wick to remove the solder. The cover should come off easily. Make sure the cover doesn't catch the windings when taking it off. OK this could potentially be a stupid question, but are the bobbins actually coated in wax or is the wax just on the wire itself? Essentially, after the cover is off, is everything covered in wax? Thanks for the reply...I'll definitely give it a shot.
Millennium Maestro Posted October 28, 2009 Posted October 28, 2009 OK this could potentially be a stupid question, but are the bobbins actually coated in wax or is the wax just on the wire itself? Essentially, after the cover is off, is everything covered in wax? Thanks for the reply...I'll definitely give it a shot. yeah evrything will be covered with wax under the cover. I have also used a dremel to cut through the solder so I could remove the cover.... saw that on a tech page! I personally like exposed pickups, in the case of my 155... one was all black the other was a zebra underneath, just giving you notice you may get a little suprise. M.M.
slider313 Posted October 28, 2009 Posted October 28, 2009 Use a flat tip on your iron...not the pointed tip. Just heat the solder and use a flathead screwdriver to slightly push" the cover away from the solder bead. Hold it a few seconds until the solder cures and do the other side. They should pop right off. If the wax is all over the bobbins, place the pickup on a paper towel and heat it with a blowdryer on medium heat.
Salutemysolution Posted October 28, 2009 Author Posted October 28, 2009 Cool. I really appreciate all the help. I'm really curious to see what's underneath. Actually a mismatched pair would be pretty cool in my opinion.
Thundersteel Posted October 28, 2009 Posted October 28, 2009 Actually a mismatched pair would be pretty cool in my opinion. How about clear?
SouthpawGuy Posted October 29, 2009 Posted October 29, 2009 How about clear? Must be the Sesame Street signature model. Hook 'em while they're young eh ?
Millennium Maestro Posted October 29, 2009 Posted October 29, 2009 Must be the Sesame Street signature model. Hook 'em while they're young eh ? My guess is the Partridge Family/ Lol
tulk1 Posted October 29, 2009 Posted October 29, 2009 How about clear? Looks like a Gibson Jimi Hendirx signature SG. To go along with the Strat(ish) and the Piano. ..........
slider313 Posted October 29, 2009 Posted October 29, 2009 It comes with a complete set of "My Little Pony" figures in all the colors.
