thunder Posted December 26, 2009 Share Posted December 26, 2009 Hello. I just recieved a new Kenny Burrell amp and I have reverb problems. Number one, when the stand-by switch is flipped on the tank crashes like I have just kicked the amp. This always happens when the level control is turned up. Now, after about an hour of use, the reverb level is so low that it can barely be heard. The Dwell control works just fine but the level has a problem. I have checked the tank and it is fine. The tubes are all okay. The cables are fine. Voltages seem normal but without a schematic I could be missing something. Can anyone help? Link to comment Share on other sites More sharing options...
212Mavguy Posted January 1, 2010 Share Posted January 1, 2010 Hello. I just recieved a new Kenny Burrell amp and I have reverb problems. Number one, when the stand-by switch is flipped on the tank crashes like I have just kicked the amp. This always happens when the level control is turned up. Now, after about an hour of use, the reverb level is so low that it can barely be heard. The Dwell control works just fine but the level has a problem.I have checked the tank and it is fine. The tubes are all okay. The cables are fine. Voltages seem normal but without a schematic I could be missing something. Can anyone help? New as in under warranty? Link to comment Share on other sites More sharing options...
