New Member...New Heritage
jazzbone
Both of those are exceptional... Great looking Heritage there , Jazzbone.
And both are dots..... I guess they were custom ordered that way and not a different model of the H150-CM.
I assume that the label just says H-150CM ?
Actually, the label says H-150 Spec OSM. No mention of CM
The 150CM Specials only came with dots. Attempt at a less expensive 150, yet still have everything else the regular runs have - killer tops, excellent hardware, k'zoo mojo and on and on. Only dif I can remember is the dots v traps.
Jazzbone - that is one killer guitar! Give the stock pups some time. You may find they grow on you, much the same as the hardware is doing. Then again, pickups are relatively inexpensive and easy to swap. Could be fun. :D
tulk,
Thanks for the advice. Do you know what Heritage used for caps? They don't appear to have any markings, just yellow in color. I was thinking of trying some different tone caps, maybe vitamin Qs. Any thoughts?
tulk,
Go to RS guitarworks and order either the Reissue bumble bees http://www.rsguitarworks.net/rsstore/produ...products_id=452
or the reissue grey tigers (they are the same only differ in appearance http://www.rsguitarworks.net/rsstore/produ...products_id=453
TRUST ME, THESE ARE THE GUYS THAT GIVE YOU THAT GREAT VINTAGE MID-RANGE TONE..... GARY MOORE.... JOE WALSH.....
TRUST ME. THEY ARE IN ALL HERITAGE AND ARE THE BEST LOW COST INVESTMENT IN THE WORLD FOR TONE!!!!!!!!!!!!
thanks Kuz...I'll check RS out. Have you found that changing the caps have improved the tone of the Schallers?
Mine's M19104 fourth guitar of June, 22nd
That's too slick. I will call Jim and tell him the relationship.
Schallers in Jim's 150 are a little tame. You need to use your amp to get your tone. But if you ever need to go clean the Schallers will give a very bright - almost, well kinda' - Rick tone.
My 150s have: 1. Lollar p-90s 2. Throbak pickups 3. & 4. have Tom Short Marc Ford Tombuckers
I honestly never cared for any of the Schaller pups, but these RS guitarworks caps can only help.
If you decide to change the pups Tom Shorts are only my short list of BEST PICKUPS and are very affordable consider what you get!
Yeah, I've been hunting around for replacement pickups and Tom Short is on the short list, along with JS Moore, Wolfetone Dr Vintage and Lollar Imperials. I'm trying to sell off some rack gear to gather the cash. Seems like everything I like is $250+. I may go the used route. Have you heard of Brian Gunsher (BG pickups)? I've been reading some good things over on TGP about him and his sets are very affordable.
That confirms that it is a H-150 Special and not a custom ordered H-150CM . I would expect the finish to be OSB , Old Style Sunburst.
I had heard good things about Vitamin Q caps also. I have Bumblebees in my 157 that has the Sheptones, that guitar sounds great.post-1051-1269797399_thumb.jpg
Right...That's OSB not OSM. I think bumblebees are the way to go. Expensive but well worth it...
I have had Bryan custom wind two different sets of single coils for me. Bryan is easy to deal with, knows his stuff. If you go that route you won't be disappointed. And he's very reasonable, price-wise. Thing about custom pickups, they're getting like guitars. So many to try, so little $$s to try them with.
edit: Duh!! I have a set of his Pure 90s, with one custom cut for a smaller route, in my Stambaugh Tele.
I'm seriously considering a set of Bryan's Lizard humbuckers. Either that or there's a set of Tom Short's over on TGP if I can get the scratch together. Thanks for your recomendation.
UPDATE!
I just scored a pair of Tom Short Marc Ford Tombuckers for the H150. A pair of bumblebees' and I'll be set...
