skydog52 Posted June 27, 2010 Posted June 27, 2010 What bridges and stop pieces do the boys and girls use at Parsons St. on 535s and 555s? I should know this.
tulk1 Posted June 27, 2010 Posted June 27, 2010 They've recently made the switch to TonePros as the goto bridge/tailpiece.
Kuz Posted June 27, 2010 Posted June 27, 2010 They've recently made the switch to TonePros as the goto bridge/tailpiece. What Kenny said!
Spectrum13 Posted June 27, 2010 Posted June 27, 2010 I have seen Gotoh, Schaller, and tone pro When I got into Heritage in 2007, they had stopped using Schallers and the goto was Gotoh. Gotoh makes tone pros. The only difference I can detect on the nashville bridge between the tonepros and gotoh are the locking screws. If they now use tonepros standard (was a $100 upcharge in 2008) are they using the locking stoptail studs?
tulk1 Posted June 27, 2010 Posted June 27, 2010 When I got into Heritage in 2007, they had stopped using Schallers and the goto was Gotoh. Gotoh makes tone pros. The only difference I can detect on the nashville bridge between the tonepros and gotoh are the locking screws. If they now use tonepros standard (was a $100 upcharge in 2008) are they using the locking stoptail studs? Good question. On my last two custom orders I requested locking hardware. It was an upcharge on the Millie in 2009. They just said, "sure" on the Prospect earlier this year.
skydog52 Posted June 27, 2010 Author Posted June 27, 2010 Thanks guys for the information. When I do my next string change, are these pieces of hardware marked somewhere? I went on various sights but can't see anything marked. The Gotoh and Schaller tailpieces look very similar. Found specs, I guess I could get my calipers out and make sure.
brentrocks Posted June 27, 2010 Posted June 27, 2010 usually the tailpiece is marked on the bottom...bridge too...if it says made in germany, its schaller
