Can't decide on a grill cloth cover...
kbp810
My last amp build ran into one major flaw... the left speaker cone was hitting against the power transformer. Since I made the mistake of epoxying in the baffle board, not much I can really do to fix it; so I started back from scratch - well not total scratch, I am going back to the first maple cabinet I had started in the first place.
So far it's curly maple stained with a sort of light red/brown'ish color, trimmer with birdseye maple that will be finished natural, and for over the faceplate is ambrosia maple that I also plan on finishing natural (not sure at which pointed I deciced to go with all maple!)
I am having a really hard time deciding on what color/pattern grill cloth to go with on it though... mojotone has a light oxblood that I am leaning towards but can't make up my mind.
Any thoughts from the HOC?
Here's the box so far -
This is the light oxblood I am considering...
http://www.mojotone.com/amp-parts/Grillclo...ood-36W-SPECIAL
My Goodsell and Hayseed both have that Oxblood grill and the tweed coverings -
I think they have that Oxblood with goldthreads too. Love the combination maroon and tan / gold /natural maple
I am colorblind as it gets without seeing grayscale, so bear with me.
From the finish you described, I would go with a darker grill cloth than the finish. From there, I would try to find something with an interesting pattern in it sort of like Vox has. Not JUST like that, but you know what I am saying. Subtle but present. That's what I would shoot for initially.
Thanks for the input!
- They have this one at mojo as well which I think is sort of along the lines of what you're describing above. I think the darker color will help cover the speaker/baffle better as well
I think I'm going to roll with this one
http://www.mojotone.com/amp-parts/Grillclo...rill-Cloth-36-W
Now that would really contrast the maple nicely ;)
Oxblood it was! The material was a little thinner then I thought it would be, so I stained the baffle board a dark red to help it blend in better
Schwing!!! Nice work kbp810!
I estimate that you understand the Tit for Tat reverse roll that requires a whack on your amp for each play on any said H137.
It's all good. Nice Work!
Indeed I do my good sir, I believe we have an accord ;)
Good choice and I like the TV look. That's pretty!
Is that a Martin D28 holding open the window?
Please, I only use D50's to hold up my windows!
(Actually, it's just an old beat up cheap fender that I can't figure out why I haven't tossed yet - has a twist and bow in the neck, truss rod is snapped, bridge is half coming off, ended up donating the tuner's to a friend who made himself a cigar box guitar)
