help out a new guy
big bob
How would I go about using a microphone with an acoustic guitar, ie what equipment. Do you use a guitar amp with a mic? or a pa? or what.
I am totally clueless on this please help!
Not sure how much help this will be... but I've played through a Shure 57 dynamic mic hooked up to a guitar amp via a transformer/XLR-1/4" adapter, I was playing through an old silvertone and had halfway decent results
Ideally I think you'd want to play through an acoustic amp (even if just playing through a microphone), but of course I'm sure a PA would really be the ideal route.
I'm not really a subject matter expert on this topic, just throwing my 1.5 cent's worth out there
I agree ...
Assuming that you want to amplify the acoustic and it has a piezo...
Basically , an acoustic amp ( or a Keyboard amp ) is a small PA.
But , there tends to be bargains on the local craigslist and music stores on PA stuff alot nowadays.
Kind of depends on how loud you want to get in what size room.
I agree ...
Fred No pickup NONE. think acoustic L-50
How would you mic it. through an amp or a pa.
straight through? other
in any event no pickup, just a mic.
In my example, I just had the mic hooked into the amp, and the mic on a stand aimed at the sound hole about maybe 6 inches or so away. For guitar amp you'll need an adapter/ transformer - they're only about $15-$20'ish. Otherwise with a acoustic amp or pa you would connect the mic directly via xlr input
any preamp or buffer needed?
Nope, essentially the same basic simple setup for vocals, just that your guitar will be doing the singing instead
Thank you kind sir.
Some of the best solo acts I have seen use two mikes, one in front of the guitar and one in front of their face (for singing of course), and both going to a simple PA system.
You may need to use some kind of DI or preamp for best results. Just to give the signal a bit of a kick before it hits the PA. Fatter fuller less noise.
I personally Hate piezo pickups..YMMV..Last acoustic gig I did we just mic'd em, ran em through the board, added a little reverb, and voila! It sounded great! We had the advantage however of not using a drummer, so feedback was not an issue..My 2 cents..
I agree I hate the sound of piezo & takamine pickups...they sound SO much better with a real mic
*edit* a rode NT4 is a great mic for recording, and you could probably use it live too
but you can't go wrong with an SM58
